74 k10 going 55 mph is at 3,500 rpm
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Does it run reasonably well, sluggish? How is the timing?
granthendrickson
grant
She run’s pretty damn well, I rebuilt the engine around 300 miles ago. She’s got a stock bottom end, .30 bore, heads from a 71 camero, new edlebrock intake, 1103 summit cam, headers and a street fire msd distributor
JBswth
Vallejo, California
James
C25
292 cubic inches
I got a 1974 k10 with a 203 transfer case, turbo 350 and a 355 sbc. The rear gear is 3.73 and at around 55 mph cruising the rpm’s are up to 3,500. That seems a bit high to me, does anyone know what I should do to the truck to get lower rpm’s at 55? I’m also getting 8mpg.
3500 at 55 MPH? You must have 4:56 gears for the engine to be revving that high. Others are saying that maybe your trans isn't upshifting into 3rd, but I have a hard time believing that you wouldn't be aware of a problem like that.
J.B.
JBswth
Vallejo, California
James
C25
292 cubic inches
A good way to tell is to jack the rear end and have a couple of buddies turn both rear wheels together one complete revolution, and you see how many revolutions the driveshaft turns. If you have 3:73 gears, your driveshaft will make a little less than four complete revolutions, but if it makes more than four, you don't have 3:73 gears, you have something deeper.
J. B.
78ALB
