eskimomann209
- Jan 9, 2019
- Modesto
- Marcus
- C10
Alright fellers. Not sure what happened. Old age probably. But the dome light won’t light up an incandescent bulb and emits very low light on an LED. The socket measures out a 12.5ish volts but my resistance is high when tested with the wiring unplugged from fuse panel and tested agains known ground.
The light is dim when the headlight switch is used and/or the door is opened. Under dash light is bright as the sun! Think I should run wires from switch to the plug behind the seat ? Or run new wires all the way down to the fuse panel? Do we think wires? Socket contacts look pretty clean.
