- Oct 27, 2016
- MO
- Spencer
- 1971, 1̶9̶7̶4, 1976, 1979,1̶9̶8̶5, 2002
- Dart Swinger, Sierra 10, C10 Cheyenne, C10 Big Ten, Silverado 10, Ram 2500
- 225/6, 350 c.i., 350 c.i., 5.9l Cummins
Personally I would cut the part above the heater box how I did, all i used was a piece of 1.5" schedule 40 pvc pipe to form it. For the area behind the engine I would first try to spot blast it or some type of rust remover, if holes start to show then replace, if it seems to remain intact then clean good and coat with some type of covering to protect it and make the piece in front of it.
If you do need to replace-
I would cut the bad out and make smaller pieces as opposed to one big piece as it appears you only have 2 major spots. Get yourself a sand bag and some rubber, wood mallets, or plastic hammers and experiment with making curved pieces
