700r4 Will not shift out of first.
Nick.koehler6
IL
Nick
350 5.7L
Hey guys, I have a 700r4 transmission in my '83 K10. It sat for about two weeks. When I went to go around the block for a test ride. I noticed that it would not shift out of first gear. I have P,R,N,1. I have adjusted the TV cable multiple times and have looked at the governor. Both were good. When I was driving I got the truck upto about 5k RPM. I can not downshift or up shift manually. I drained the fluid and it looks brown but doesn't smelled burned. I changed the AT fluid 100 miles ago. Should I swap the filter and fluid again?
yevgenievich
Viktor
sad
very sad
less sad
have you tried pulling on the tv cable while the truck is idling in neutral couple of times. This usually will release the valve if it is stuck. It is not uncommon for the valve to stick, and there is a helper spring that can be installed in the valve body to keep it from happening.
350runner
tx
Ceasar
This^^^
Nick.koehler6
IL
Nick
350 5.7L
Tried that..didn't work
350runner
tx
Ceasar
yea that bad boy is stuck. try pulling the cable a lil more tight and going for a drive.
yevgenievich
Viktor
sad
very sad
less sad
700r4 also still uses a governor and it is possible for it to stick as well. But the only way to check is to pull it out.
Nick.koehler6
IL
Nick
350 5.7L
Checked,pulled and cleaned the governor..Ill try the cable again tomorrow..any more suggestions?
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
How dark was your fluid? And you can check the shift linkage adjustment for ***** and giggles.
Nick.koehler6
IL
Nick
350 5.7L
It wasn't too bad, could still see that it was a reddish Colo. No big chunks in the pan..I changed the oil and filter..gotta let the battery charge up. Z(too scared to test drive)
PrairieDrifter
North Dakota
Mason
Something had to of gotten stuck or hung up if you haven't drove it in two weeks and it just doesn't work now
chengny
A TSB on this:
TSB 88-16 (Mar)
SUBJECT: GM TRANSMISSIONS
PROBLEM: No upshift
CAUSE:
May be caused by imprex material lodged in a seat or under a ball in the governor. Imprex material is used to seal transaxle cases against porosity and has the appearance of RTV sealer. This material can prevent the governor balls from seating properly, or can plug the feed passage and result in low governor pressure.
CURE:
If it is suspected that imprex material has migrated into the governor, remove the governor from the transaxle. Reinstall the governor cover without the governor. Start the engine and shift transaxle to drive for approximately 5 minutes. This will flush out the governor oil passages.
Clean the governor and check for proper seating of the governor balls. Hold the weights outward against the bails and pour solvent into the governor shaft. If solvent leaks past the balls, replace the governor. If no leakage is found, reinstall the governor and verify operation.
And just a general checklist for a "1st gear only" condition:
1st Speed Only No 1-2 Shift
1. Governor valve may be sticking.
2. Driven gear in governor assembly loose, worn or damaged.
3. The 1-2 shift valve in control valve assembly stuck closed. Check governor feed channels for blocks, leaks, and position. Also check control valve body gaskets for leaks and damage.
4. Intermediate clutch plug in case may be leaking or blown out.
5. Check for porosity between channels and for blocked governor feed channels in case.
6. Check intermediate clutch for proper operation.
Nick.koehler6
IL
Nick
350 5.7L
Well, I drained the old fluid removed old filter and changed it all. Played with the TV cable off, played with the governor and nothing is working..rebuild time?
350runner
tx
Ceasar
Did you try leaving the governor out starting the engine and putting it in drive for 5 mins? Worth a shot.
Nick.koehler6
IL
Nick
350 5.7L
Ill try it tonight! What would thAt do? Do I just let it idle or should I drive it around the block?
350runner
tx
Ceasar
If there is any debris it will clear see post #11 @chengny
12turnda
