700r4 transgo shift kit tips
Obwonkonobe
AZ
Ethan
C10 custom deluxe
I had my 700r4 rebuilt a year ago and it has held well, but I wanted a little more and installed a corvette servo as well. Well now I’ve got the itch again and have purchased a transgo 700-2-3 shift kit from summit. It seems a little involved but I found a video from the 90s produced by transgo that should help. I’m just wondering if there’s been another video or good guide made more recently, or if anyone has any good tips. I’ll be leaving the trans in my truck to do this so I’ll only be touching the valve body. Thanks!
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Work slowly, have plenty of time and space to lay out the parts. Get some petroleum jelly, put it in the freezer for a few hours before you start putting things back together. You will be fighting gravity installing the pressure regulator parts, if you pack the valve bore full of vasoline it will hold things in place.
You may want to order a replacement spacer plate, and aluminum accumulator pistons. The checkballs cycling against the plate tend to wear the holes oversized, and if the accumulator pistons are plastic you will definitely want to replace them. Make sure the accumulator holes for the alignment pin aren’t wore oversized or egg-shaped, if so, replace them.
Good luck!
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Good luck!
I’ll keep an eye out for any wear in the moving parts, and good tip about petroleum in the freezer! Do I need to flush the fluid to get it out? Or is it okay to have some diluted in the trans
71RAT
Deerfield NH
Kirk
K20 Scottsdale
I've used TransGo products for years, hundreds maybe thousands. First thing that comes to mind is, they make quite a few changes to the input housing internals. Not sure if you will have any adverse effects, only doing the VB and pressure regulator modifications. Good luck with it!
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
You can leave it in there, it'll disperse itself.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Just make sure it’s petroleum jelly!! Bearing grease won’t dissolve, next time you have the pan off it will still be there in a big blob.
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Good to know
K5ride
Apple Valley, CA
Steve
C10 Stepside
I usually use one of the auto trans assembly lubes. They are inexpensive and dissolve well. They also hold everything in place very well.
JoeR Jr
Stokesdale, NC
Joe
6.0/4L80E
I'm also a fan of Transgel. It's cheap enough.
Joe
Tombo
Auburn, Al
Thomas
K5 Blazer
350 Vortec
When I rebuilt my 700r4 I used the Transgo sk700 noyoyo kit, Corvette servo and replaced the accumulator pistons with aluminum. Also had a boost valve upgrade. I got nice firm shifts all the way to 4th. I love it so far
JOD26
