700r4 to th350
jth678
georgia
john
v10 custom deluxe
yes it is tbi.
jth678
georgia
john
v10 custom deluxe
here she is! traded MY 1986 honda 250r for this!
Swims350
Logan WV
none
nice trade, good looking truck cowl hood and all, lifted short bed, awesome deal IMO.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I just realized you have a 4WD, so some of what I said may not apply (driveshaft, etc), but it sounds like you have most of that covered (along with the adapter from Advanced Adapters). But as far as the VSS and computer goes, you're all set.
jth678
georgia
john
v10 custom deluxe
yea they are the same they are both 27 spline i was worried about that at first too.
Swims350
Logan WV
none
I converted my 88 tbi 4x4 from a 700r4 to a th350, I had the kit from tci or tecpak fittzall or whatever, short shaft and a spacer that was like 1.xx thick, bolted right up in place, I had NO driveshaft length mods, NO crossmember mods or movement, just all right in place.
My shift linkage bolted up and everything, you must run you a vac. line to the 350 modulator, not a big deal though, and then when your in dash indicator(if it works) will say it's in od when it's actually in d. It will also not shift down into 1st because 2nd will be 1st. Nothing is that big of a deal though. we drive mine on the street, hauling, unloaded, highway everything, has good power and plenty of grunt and I just have a stock 350 rebuilt with tbi and run 3.42's out back and up front with 33's on it now.
It ran great, but now I got hiccups with the tbi setup so soon it's gonna be carb'd.
Snips71
