700r4 not hitting 3rd gear
truckin'vermont
Montpelier, Vermont
Bob
Hey y'all, new one here -
So I only run my truck about a dozen times each summer - want to keep it clean from VT road salt. Anyway -
I've got an '86 with the 700r4 tranny, and I can't seem to ever find 3rd gear. It goes directly from 2nd to OD, which just isn't good at all. And tonight for the first time, it gave me trouble when I would apply moderate pedal in overdrive - seemed to stutter a bit.
Now I can change my oil and do my own brakes, but that's about as far as my mechanic skills go. Would love to hear anyone's thoughts.
Fluid will be changed soon - it's full, and still red (although not as red as it should be).
Thanks in advance.
87dieselburb
Massachuaetts
V1500
I had a 700r4 in my 87 it started to give me the same problems and I did some reading and everywhere I read said to get rid of that Trany and get a 4l80e so I looked around and did my research and found out they improved all the week points of the 700 then I went to have one put in and it was a jasper built and they made even more improvements all heavy duty stuff worth the money for a brand new better than stock transmission and it's a one time fix
mistaake
SF Bay Area, California
Michael
Crown Vic
700R4 was later modified and renamed to 4L60E.
the 4L80E is a much heavier duty transmission. It's basically a descendant of the TH400 with an extra gear (and many other changes of course).
Thanks in advance.
Have you had any luck fixing this or have any new news?
yevgenievich
Viktor
sad
very sad
less sad
I am wondering if the torque converter is locking up in 3rd or possibly a cross leak internally
johnalen76
