6hk1 isuzu in a 79 k20
blaizewedlake123
US
Blaize
k20
Thoughts?
Sent from my SM-G960U1 using Tapatalk
blaizewedlake123
US
Blaize
k20
You think it would fit without cutting the firewall? I mean if not it's no problem I just wanna try to avoid it if i can
DirtyDYT
Ohio
‘79
A big block chevy not including accessories is what, around 30-31” long and about 700 lbs. They sit about as far back as they can in these trucks. The Isuzu 6HK1 is 53” long and 1300 lbs. I’m not sure where you’ll find the extra 2 feet without getting really creative but by all means...
blaizewedlake123
US
Blaize
k20
My brother said it would fit.
Bc it would I know it will it only has a foot on a 12v cummins, so all I'll have to do is cut the fire wall
Maybe add another set of tires in the front to help with the extra weight!?
That needs an 8ft mower under it. It'd be like a king sized Gravely.
roundhouse
atlanta ga
justin
77,78,79,80 ?
What’s the Isuzu four cylinder ?
That’s in all the box trucks
Someone used to make a flywheel and motor mounts to put it in a Chevy
The 6 cylinder in question is gutless enough, I'd hate to drive one with 2 less cylinders.
Big Chip
Michigan
Kevin
C35
I own one and although it would actual fit in the truck in question, it is indeed gutless. There seems to be no aftermarket tuners that offer box truck performance packages but maybe I just didn't google deeply enough? I learned a long time ago that the wheel doesn't need to be reinvented but not all of us got the memo.
norman baker
ellijay,ga
norman
1976,1981,1982,1984 1985
k20 ,c10 ,c10,c20, c10
none, 250 ,305, 454, 305, 454 ,
IS IT TURBOED? MAY NEED THE INJECTION PUMP TWEEKED? AND REAR END NEEDS TO BE LIKE? 2:73 . LOW ENGINE RPM ENGINE .
Cryptik
