Mango
- Dec 22, 2021
- JacksonWyoming
- Gil
What oil do you use in a old high milage engine ??
I’ll assume you posted this in jest. For the rest of the crowd, while ATF may work in transmissions and transfer cases and serve as a good injector cleaner for old diesels, there is no plausible reason to add any to ANY engine’s motor oil. Unless your goal is to turn good oil into bad and wear out the engine quicker.Walmart Supertech 10w30 with half a quart of ATF.
I've been using a half quart of ATF in my engines for 30 years with no problem, plus they're clean enough to eat off of inside.I’ll assume you posted this in jest. For the rest of the crowd, while ATF may work in transmissions and transfer cases and serve as a good injector cleaner for old diesels, there is no plausible reason to add any to ANY engine’s motor oil. Unless your goal is to turn good oil into bad and wear out the engine quicker.
