- Sep 21, 2017
- Long island
- Rich
- Suburban V2500
Someone needs a proper scanner. This means you.
Code reader for a PCM controlled vehicle is about as important of a tool as a set of wrenchesIs there a cheaper alternative? I don’t really have a will to spend several hundred dollars to see what’s going on, after it’s all good and well I’ll never use the tool and usually I’m all for new toys
The 0411 has a P/N rev limit and a normal mode rev limit. If your tuner didn't change the P/N rev limit and the ECU thinks you are in P/N, then yes.Would that you think make the truck always think it’s in park or neutral though and make the rev limit really low? I don’t plan on revving it really high I just need it drivable
This is what I have. This will let you do anything you could ever want on an 0411 including whole OS read/write, segment swap, datalog, etc... using TunerPro RT, Universal Patcher, LsDroid, or PCM Hammer/logger. Thats all free software once you have the tool.I have a code reader but that’s about all it does, it has a live data option but none of the numbers change, that’s a walmart obd2 reader for ya
You need to start replying to a post or @ the persons name you are talking too. I often end up losing track of your threads because you don't actually reply or tag me when you are asking or replying to someone and I never get a notification. Next thing I know the thread is 10 pages longer than the last time I responded and I have no idea what is going on.Which model do you have? Mines a little red handheld thing and it doesn’t do anything other than read codes
You said earlier you cleared it and it kept coming back. I forgot to add the link originally. I edited the post to add it.@Bextreme04 where’s the walkthrough? I cleared said code and it didn’t come back, I could’ve had something loose etc. the harness on this engine I haven’t touched, I bought engine harness computer all together from Murray ky, dude cuts and works the harnesses
