5.3 with an sm465
T Anderson
Nebraska
Terry
I just sold an engine I had originally planned on putting in my 86 GMC to buy a more fuel efficient 5.3. I'm wanting buy a whole donor vehicle that way I can have all the wiring I'll need and can part it out and get some of my money back. (And maybe swap the seats into my square) the question is how hard will it be to do the swap and keep my sm465 in my pickup? I eventually want to put in a t56 but don't have the money right now. I need something I'll be able to drive from Nebraska to California or virgina.
350runner
tx
Ceasar
Chevy kept the same bellhousing bolt pattern through out time should be simple as any swap.
MadOgre
NA
NA
NA
NA
NA
Ya but how many LS engines came factory as a manual ? You will need to find a flywheel for that LS engine.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Early GMT800s could be had with a 6.0L and a 5 speed in the 2500HDs. Should be able to find a flywheel and clutch disk to work with it.
T Anderson
Nebraska
Terry
I haven't really found much online about a manual transmission 5.3 swap.
Joe383
Moses Lake
Joseph
I would add an over drive to the M465 it will give better results than the LS swap using a ranger torque splitter. There about $1,600 and will add an over drive to your existing transmission. It looks like a little bit of work to install one but your RPMs are a bigger problem than the motor efficiency.
MadOgre
NA
NA
NA
NA
NA
At that price he is probably better off just going with an NV4500
Carb'ed Vortec 350
But then he wouldn't have the coolness factor having twin sticks.
If my '65 didn't already have an overdrive in it, I'd be swapping in my Ranger Overdrive. I am still kicking it around just because of the coolness factor. An SM420 and a Ranger OD would be a cool setup.
firebane
Calgary, AB
Curtis
I just saw this thread and in no way would I put a sm465 behind a 5.3. As stated if you truly wanted to stick with a standard got with the nv4500.
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Wanna get rid of that sm465 if you go a different trans route?
Sent from my SCH-R530U using Tapatalk
HectorGarcia415
