5.3 into 81 k20 with th400 np208 questions
jason81k20
pennsylvania
jason
k20
I'm trying to get all my notes together so when I put the motor in the trick finally I'll have everything. And I'd rather get advice from you guys that have done this, I've spent hours on Google! I've already cut down my harness, no trans, emissions etc
My questions,
1.) What's the easiest, cheapest way to get the vss signal using my th400 and 208 case? I've read about different adapters and what not but it'd be nice to see what you guys have used
2.) What's the best route to go for a fuel pump?
3.) Do I need to use the newer trucks radiator and fans?
Those are my biggest questions so far everything else I think I have an idea of what I need
AJII
Jackson, TN
AJ
Here ya go. good luck to you!
My questions,
dakota digital pulse generator
87 tank and sender. 96 silverado fuel pump
factory radiator, ls clutch fan
jason81k20
pennsylvania
jason
k20
And I can use the Dakota pulse generator with my factory Speedo and everything?
Thanks for the info man!
Sent from my HTC6500LVW using Tapatalk
AJII
Jackson, TN
AJ
you cant
aaron06
