4L80E TCI EZ TCU Error code issues
pilot940
Corey
I finally installed my 4L80E in my 82 c10, everything hooked up great.
However I am getting several error codes and erroneous data.
I have checked and rechecked all the wiring and connectors.
Error Codes:
TOT Error
Over Temp
TPS Error
Batt Error
Erroneous Data:
Trans Temp 255 (when cold)
Bat Volts .5 (Meter reads 12+)
TPS at 34% (Set at .5 volts idle and increases as throttle is depressed)
I am pulling my hair out with this thing, I tried to call TCI, but they are gone for the weekend. I am guessing the controller is bad, but if anyone has experienced this your help would be greatly appreciated.
Thanks!
1low4x4
Nick
Main wiring harness connector on transmission is plugged in 180* out. Flip it around. Yes I realize how old this post is
