4L80E problems
Maaac1789
Booneville, MS
Brent
Hey guys. Need some help. Long story short: I have a 1983 K10 that I 5.3 swapped last year. I initially used the 700r4 behind it, but it didn’t hold up. I swapped in a freshly rebuilt 4L80E, and had my programmer do a segment swap with HP Tuners, but we can get it to shift on its own. He can command it with HPT and it shifts, and it will do a WOT shift at around 40mph, but won’t ahift by itself. I checked continuity between the PCM and the tranny plug, front and rear speed sensors, and the TPS. All good. I’m using the NP 208 t case and a Dakota Digital pass through VSS. We changed a setting and got the mph right in HPT, but still no shift. Any ideas? Thanks
4WDKC
Southern Florida
Kacy
Did you repin the harness for the 4l80?
http://lt1swap.com/4l60e_4l80e_harness.htm
Looking to do a similar swap so what tcase did you use and what adapter to bolt it to trans? How much did it affect your driveshafts and is it lifted?
Maaac1789
Booneville, MS
Brent
I actually bought a 4L80 harness and cut the wires I needed from it, since I had removed the tranny wires when I first did the swap. I’m using the stick NP 208 t case and using an adapter that came behind a 4L80. Bolt holes line up the same even though the 208 is passenger drop. It didn’t effect my driveshafts because I moved my motor forward 1-1/2”.
4WDKC
Southern Florida
Kacy
did you move the wires at the ecm plug like the site above says?
rpcraft
Robert
LS 6.0 364 CID
ARe you running a VSS from the trans or the transfer case?
Maaac1789
Booneville, MS
Brent
Yes,I repinned the wires at the ECM.
I’m using the Dakota Digital pass through VSS the speedo cable on the transfer case passes through the VSS. Model number SEN-4160, if I remember right.
Maaac1789
Booneville, MS
Brent
As you know the 4l80 had 2 Soren sensors. The input is in the tranny, but on a 4x4 trans, the back sensor would run off the stock t case, but mine didn’t have that one so I decided to use the DD unit.
rpcraft
Robert
LS 6.0 364 CID
OK, just checking. A lot of guys miss that and its a troublesome issue.
Maaac1789
Booneville, MS
Brent
Update: I finally found the solution on HP Tuners forum. Because the Dakota Digital VSS reads off the speedo cable instead of the trans shaft, we had to change a few settings under the speedo tab in the tune, so it could properly calculate the correct speed. Shifts like a champ now. Don’t let anyone tell you a pass through pulse generator won’t work. It will...perfectly.
rpcraft
Robert
LS 6.0 364 CID
I know they will, just what happens is people aren't willing to adjust settings very often to account for a budget piece of hardware. A lot of tuners fall into a habit of doing what they know and not looking beyond for answers. Sounds like you did your homework.
1998_K1500_Sub
