472 Cadillac Motor
custodian
Catawba
William
5.3 LS, 350
Will a 472 Cadillac motor bolt to a Chevy 350 Turbo trans?
74 Shortbed
If I remember right the 472 has the BOP bolt pattern so you would need to swap over to a BOP case, no biggie..
There used to be an adapter plate available.
beest
indiana
matt
Ive been thinking of the same kinda swap. But Ive already swapped a 5.3 into my k10.
Ive got the '70 500 caddy engine and th400 trans, id just need another truck to swap it into. The th400s are easy enough to pull apart to swap in the short 4wd output shaft.
Sent from my SM-G920P using Tapatalk
willi
