OldBlueDually
- Jun 8, 2020
- Minnesota
- Justin
- 1976 GMC
- C30
- 455 Olds
Hey there gent's, I need some advice on this here issue.
I finally got to the point of dropping in the engine to see what needs to be done to get it mounted up. I bought some frame to engine mounts from summit racing that looked like they "should" work, this was just a shot in the dark.
As you can see from the pics, they don't work. As for the engine mounts themselves, I just re-used the ones I had on it.
Are any of you aware of a combination that will work to get this baby mounted correctly? I have been searching for a set of Olds 350 diesel mounts (from GM trucks '78 to like 82 I believe) and did find some from a guy, but he is in the process of moving and has not come across them.
So I just need a nudge here on what to do as this is the first time dealing with putting an Olds in a GM truck.
As you can see, to mount up the transmission is way off too. I have my adapter plate in place and ready, but don't want to be forcing things to fit.
Thanks in advance!!
Thanks in advance!!
