shanegtr
- Sep 29, 2018
- Perth, Australia
- Shane
- R2500 Suburban
Ok, just putting it out there to see if anyone has any ideas here. As the title suggests, 454 TBI. Starts and idles fine and accelerates smoothly under light throttle, but get 1/2 throttle or more and it seems to bog down and not deliver as much power as it should(had more power available previously).
Things replaced so far (not because of this issue - just what Ive done as its a new vehicle to me), spark plugs, air filter, fuel filter, engine oil & filter(theres a nice oil leak around the filter but thats another story), coolant and thermostat, trans fluid changed and new pan filter and new fuel pump (old one died - which I thought may have been the issue). Timing was checked and at idle it was spot on 4deg as per the manual.
Any suggestions on what else to check?
