4 barrel, qjet hook up pics, bay clean up
roving4s
America
xxxx
I want to clean up the vac tubing mess. There's some stuff there that wasn't hooked up to begin with. I know everyone hates cleaning up the po's ****, when you can't figure out what they did.
84 k10 350/350. All the big stuff like fuel,pcv are fine. I went to change the gasket (which was broken and all that held the carb down was 2 long rear bolts). There's 1 line running from the rear of the engine, 1 cable with spring, 1 that connects to the front passenger side of the car- that end is connected to another fitting beside it on the carb.
Then the egr **** is a mess. Already ordered a block off plate- wasn't working anyways not with all the solid black crud/gum in it.
I'd like to run it with only what's required and yank the rest of the ****.
Not used to carbs- or sbc so pics would be great Thanks.
chengny
Boone83K10
Boone, NC
Benjamin
Wow it does sounds like I need to come help a feller out.
roving4s
America
xxxx
lol I wanna get this thing squared away. Other wise I won't :driver: it far from home.
gpmorgan
Tupelo Ms.
greg
If you don't have to wory about emission tests, I would get rid of everything but what I needed.
Vacuum to brake booster.
Vacuum to dizzy.
Accel cable.
TV cable to trans.
Boone83K10
Boone, NC
Benjamin
There is no emissions in NC for vehicles older than 1996. After a vehicle is older than 35 years you don't even have to get a safety inspection.
gpmorgan
Tupelo Ms.
greg
I can understand doing away with the emission test on an older vehicle. I'm not sure I understand doing away with a safety test on a 35 year old vehicle though. Seems that would be when they needed it the most.
roving4s
America
xxxx
That's why I keep getting older ones :) Besides who needs all that ecu **** ?
Newest I've ever owned was a 97, this chevy is the oldest and first factory solid axle.
roving4s
America
xxxx
Got most of it cleaned up, got 1 that run's out of the firewall pass side beside the ac box. Dunno where it goes, got a couple others but it's running :) , something went wrong with the valve cover on drivers side rear, it's leaking like a ****.
Boone83K10
Boone, NC
Benjamin
is it pretty small? if so that would be the vacuum for the blend door inside the heater box.
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
we currently have no emission or safety inspections here. Only on commercial trucks. I think there should be a safety inspection tho, I get a ton of junks in that haven't been safe for a long while. I done a tow today that had tires so rotten I was afraid to even tow it and the girl drives it everywhere and doesn't care how dangerous it is for her and her 3 kids
Silver84k5
