383/TH350 flexplate question
Chevy Tom
Rhode Island
Thomas
I’m building a 383 SBC to replace the original 305 in my c10. The block is a 87-95 1 piece rear main seal roller block. I plan on using the Th350 that is in the truck, which will be built up. I will be using a summit brand 2500 stall converter. The engine is internal balance. What flexplate should I use? Will I need a special one? Thank you
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I believe, unless yours is custom, that engine is internal and external balance. That is what I think my 1-piece RMS Vortec is. I used a Hays SFI flex plate. If you go to summit and search for an 87 c10 flex plate, you should be in business.
Chevy Tom
Rhode Island
Thomas
the engine is custom, internal balance. Im running a neutral balance balancer and need a neutral balance flexplate. Im assuming a stock 1 piece flexplate will work. Just want to make sure.
jake26104
