rollinon35s
- Jan 20, 2016
- wooster, oh
- todd
- K20
Ok so my brother and I freshened the motor up in my 84 k20 a couple years ago and though it ran like a scalded dog with 33" tires it seems since I went to 35's and made some motor "improvements" it don't have that same snap it had.
Build is like this 350 4 bolt block bored .030,
4 relief flat top Pistons
Stock crank and rods
Comp cams 12-239-3 extreme 4x4 series
World products torquer 2 heads 170cc runners, 67cc chambers
Weiand speed warrior intake
Edelbrock 1406 carb
Hei distributor from skip white performance
Hooker headers with thrush welded mufflers and full length tail pipes
700r4 trans with upgraded governor springs mild converter (1500-2000) I believe
4.10 gearing and 35" tires
Obviously this is a big heavy truck so I don't expect a dragster but it seems like every since I went to this carb and intake set up it lost a lot of torque. What do you guys recommend to get the most of this engine?
Edelbrock 1406 carb
