2015 GMC 8 lug wheels
tiredtiretodd
NORCAL
K 25
Would wheels from a 2015 work on my 1975? Both are 8 lug
CSFJ
You would need to measure the center hub openings to make sure. I don't think the newer trucks have as large of an opening as the squares do. Pretty sure it got smaller when they did away with the solid front axles.
CSFJ
The back spacing may be different also, now that I think of it.
tiredtiretodd
NORCAL
K 25
Thanks I'll check it out. I don't know if I actually like the look of them anyway. The guy asked how much I would pay for them, I offered him $100 he said yes.
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Not a bad deal for a set of brand new wheels regardless. One other issue though is that the lug spacing is different. Pretty sure the older trucks were 8x6.5 whereas the newer trucks (2000+) are 8x170mm. The brand new generation may yet be different still, but I'm not 100% on that one.
marks86
Latham, NY
Mark
12v Cummins
send us a picture of what rim they are. but for 100bucks I would buy them regardless of them fitting on your truck or not
Green79Scottsdale
G.R. - MI
Bob
No, they will not bolt on and work. As da-rabbi said, different lug pattern. And as CSFJ said, the backspacing/offset is not quite correct for our trucks either. However, both situations work in your favor because you can run adapters for the new lug pattern and achieve a more desirable offset location of the wheel. For $100, buy them! It will probably be another $200 in quality adapters to actually use them.
Tazdar
