20 inch lift k5 but problem on stearting
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
can any boddy send me a picture of how i would have to doo it thank you it will be so help full
there is no "good" way to do it. with 20" of lift, and a 106" wheelbase, that thing is going to be so unstable its ridiculous. why did you put 20" springs under it without looking into steering correction?
killerk10
Danville, Ohio
You actually would want to use a tie rod end. They are flexible where a heim is not. ORD sells their kits with them. If you look at most crossover kits, like ORD website your gonna need to run a high steer and a drop pitman on your 2wd gear box. You may also want to engineer a pan hard bar to keep the axle from walking side to side. It would be a good idea at that height.
johnmc
mass
john
k 10
305 tuneport injected
what about something like this . this was a cross over . Did you say you had a one ton front?
Chype1
