2 inch Rough Country Lift 76 K10
70ss496
Lone Jack MO
My son and I are rebuilding a 76 K10. Right now we are stripped down to the frame and starting to go back together. We are doing a small lift, 2 inch Rough Country.
Their website says we can run 285/70/17 or 33x12.50r17 tires.
What are your thoughts on each with the 2 inch lift. The 33s are quite a bit more $$ but wondering if anyone has any pics of this setup.
Thanks-Matt
Strick
Dunn, NC
Harold
C20 Crew
As long as you're not running an extremely negative offset wheel then the 33 should be no problem. I have 33x12.50 on the factory 8 inch rallye wheel on my 82 K15, with no lift.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I might be able to get pictures of a 2" lifted k10.
Redfish
Prairieville, LA
Andrew
V1500
Thanks-Matt
I went with a Skyjacker lift and modified it slightly to suit my taste. You can call it a 2 inch lift. I am running the 33x12.50-15 Coopers. This is MY look, it may not be what you want.
70ss496
Lone Jack MO
That looks great. Exactly what we are after! Thank you.
SquareInheretance
