2 in body lift for 35s?
ADTrumble
Pulaski
Anthony
Pulling cab off and dont have box on yet so thinking body lift while its all apart? I dont want anything big just a moderate lift, mabye to make room for some 35s if i need it but not sure
Never dealt with a lift so what's involved in cost and customizations
87silveradok20
Ohio
Levi
Silverado k20
I have a 6" lift and 35s and I don't think you could clear them with much less. Mine are about even with the fender so they don't stick out. And I have a body lift and don't recommend them because your fuel tanks will hang down below the body.
ADTrumble
Pulaski
Anthony
Damn i dont wanna do a large lift
But wanna get a larger tire for less Rpms
ADTrumble
Pulaski
Anthony
You have pics of what your 6in body lift looks like
I was thinking body lift would b the cheaper easyer option
Green79Scottsdale
G.R. - MI
Bob
Going to bigger tires to drop your RPM's is going to put more stress on your transmission. If you are thinking lower RPM's for better MPG's, this is not the route I would suggest. Overdrive transmission is going to be the best route.
edit: 87silveradok20 most likely has a 6" suspension lift. There are no 6" body lifts out there.
87silveradok20
Ohio
Levi
Silverado k20
She has a 4" suspension lift and a 2" body lift
87silveradok20
Ohio
Levi
Silverado k20
The front only gets close when you turn hard
ADTrumble
Pulaski
Anthony
Has anybody termed the fenders and made the result look good?? I figured it was just for muddies that r gona take a beatin
ADTrumble
Pulaski
Anthony
What size tires u running there?
ADTrumble
Pulaski
Anthony
What would u sugest for a replacement tranny it's got sm465 if i remember right with 373 gears
Witch i hear is a helluva good tranny just wanna b able to drive 55-60 without reving the **** out of the truck?
87silveradok20
Ohio
Levi
Silverado k20
315/75/16 which is like a 34.5. I've never measured to see what they are exactly but that's what the metric conversion is.
That's a good combo with stock size tires, you should be able to run 75 mph all day long and it won't hurt a thing.
ADTrumble
Pulaski
Anthony
Was using an rpm calculater and it was saying
Axle Gear Ratio: : 373
Tire Diameter: 31 Inches
Vehicle Speed: 65 MPH
Transmission Ratio: : 1
Engine Speed: 2628 RPMs
Thats 3000 Rpms at 75
Seems high to me
Seems high to me
It's only high if economy is the goal, or if you are running a diesel. A trans swap is a lot of effort to gain 1 or 2 miles per gallon.
ADTrumble
Pulaski
Anthony
No not worried bout milage
Just dont wanna run engine at high Rpms
Over work engine and over heat tranny
JoshuOne
