1991 Suburban Gearin
aglinks
Flagstaff
Alex
Suburban
5.7L
Hey all,
I have a 1991 Suburban V1500 with a 350 and TH700r4. I installed a 4" Superlift and 35" Cooper MTPs and it looks amazing. Factory gearing is 3.73 but now its impossible to get up hills so I think I need to re-gear. I am thinking of going with 4.56 and a rear locker so I can tow my jeep, any thoughts or advice?
Lu Blunt
Rye, CO
Luke
350ci
http://www.grimmjeeper.com/gears.html
Good place to calculate rpms n mphs
aglinks
Flagstaff
Alex
Suburban
5.7L
A lot of the kits I am seeing online for the GM 10 Bolt say they are for 1980-1987 GM Half Ton trucks. Did the axels change from 1987 to 1991?
marks86
Latham, NY
Mark
12v Cummins
Find a 3/4 ton burban with a 14bolt FF rear. Some had 4.56 gears, or get a cucv rear-end with 4.56 and factory Detroit and have the perches rewelded.
10bolts with big tires and tall gears are so unless on a big heavy truck.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I have the exact same setup 350, 700r4, 3.73 gears from a 90 burb axles, and 35s. I ditched the original axles with 3.08s. After the axle swap I could swear It felt as if I got another 100 horses under the hood, and it climbs hills like nothing, and cruses effortlessly at 75-80 on the freeway. But then again my truck isn't as heavy as your burb.
aglinks
Flagstaff
Alex
Suburban
5.7L
Overall my setup would be fine for probably 90% of the country. I live in Flagstaff AZ and drive back and forth to Phoenix which is a 6000 ft elevation change. The last 3000 ft of elevation gain happens over like 15 miles which is the real killer part. I dont want to put different axels under the truck because that is far more work and want to keep the truck as original as I can. Had to go with bigger tires and a lift due to my driveway being so steep and the suburban being soooooo long. My receiver hitch dragged the pavement on factory springs and 33's when I tried to drive up my driveway haha.
aglinks
Flagstaff
Alex
Suburban
5.7L
Is there any issue with installing limited slip front and rear? This truck has open diffs.
aglinks
Flagstaff
Alex
Suburban
5.7L
Looking at the charts, I think 4.56 or 4.88 is the way to go for me. Does anyone have a suburban with 35's and either of those ratios?
You are on the right track. IMHO, 4.56's work well even without overdrive.
aglinks
Flagstaff
Alex
Suburban
5.7L
I just got my gearing done. I now have 4.56 gears and a Yukon Dura-Grip in the rear. I havent had the chance to take it offroad yet but it does great at driving up hills now haha
JoshuOne
