gmbellew
- May 27, 2018
- Kansas city
- glen
- suburban 1500
The rear passenger window switch stopped rolling the window up. The window operates normally from the driver switch. The window operates down from the rear passenger switch. I looked at the wiring diagrams and followed the troubleshooting in the wiring manual (shown below for reference). I get to step 4, and there is not 12v between BRN and DK BLU when the switch is pressed in the UP direction. They do show 12V when the switch is pressed in the down direction (and the window rolls down). So this led me to believe the switch was bad. I had to order 1 switch, so with shipping being more than a switch, I just ordered 3 switches. Replaced the switch, and the window still doesn't roll up from the rear passenger window switch. I tried 2 more switches, and UP does not work but DOWN is fine. I get 12v between ground-BRN and ground-DK BLU when the switch is pressed up. But i do not get 12v when between BRN and DK BLU when the switch is pressed up as described in step 4.
is it possible that something in the window switch connector is bad/loose, or does this sound like something else? I'd like to get some ideas before I try to rip deeper into the door or potentially break the connector trying to take it apart...
