- Apr 11, 2017
- kansas
- Rick
- c20
I have a 2008 GMC 2500 that eats belts because the PS pulley is too far back. I'm simply gonna unbolt it, shim behind it, and bolt it back down. But until then I will just keep feeding it belts every 5-10k miles because I'm lazy and I don't give a **** about that truck lol
Even if that's not the RIGHT way to do it, it will still work. It should be the same with your truck. Find out which bracket is out of alignment and either put washers behind it or grind it down until it lines up right. Not a super hard fix, just look closely and you should see which pulley is the offender. This basically only works with a serp belt. Wait till it rips off one of the ribs, it will look too far back on all the pulleys (like the front rib is missing) except ONE of them will be flush up against the front and it will look too far forwards (one open rib on the back), or vice versa. That's how I determined it was my PS pulley on the '08
What I've done to correct a p.s. alignment issue was put a puller on the pump pulley pulled it to align it and pu a couple of tack welds on.Worked like a champ
