Rusty Nail
- Jan 29, 2015
- the other side of the internet
- Rusty
- C20
- 350sbc
Yep. That plug turns on the fuel pump when connected to the battery. If it didn't it's likely time for a new pump.I have put my fuel supply issue on hold while travelling for work. However, I believe I determined that I'm not getting any power to the fuel pump relay when I turn on the key. Not sure what could explain that, given that no code was shown which would seem to explain it. I also jumped 12v directly from the battery to the relay connector lead which, I think, is supposed to energize the pump as a test point. Still nothing from the pump. Any ideas are welcome.
I only recommend GM or Airtex for gmt400. I installed GM in my Blazer @ $35 bucks AND about 5 inches of fuel line. You'll see.
Make damned sure to install the new ground wire provided with the pump.
Mmmkay?
Good luck.
