1987 silverado fender replacement
Gary
Fl.
Gary
Hey everyone, I just got my first square body a coupe of weeks ago
and would like to replace the right side fender and inner fender well
because of some rust. I found a 1991 suburban in the junkyard, can
someone tell me if the fender is the same as a 87 pickup. Thanks
Yes it is the same :waytogo:
Gary
Fl.
Gary
ok thanks, going to get it now.
Keith Seymore
Motor City
Keith Seymore
4.3L
The only difference is there might be an antenna hole in the Suburban fender, for a mast antenna.
The 87 pickup would have the radio antenna in the winshield but some of the last utilities had them in the fender.
K
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
K
Keith,
I am curious as to why the moved it for the last few years. Did it offer better reception, or was it due to GMT400 having the fender mounted antenna and using the same stock, or something along those lines?
Keith Seymore
Motor City
Keith Seymore
4.3L
Keith,
I am curious as to why the moved it for the last few years. Did it offer better reception, or was it due to GMT400 having the fender mounted antenna and using that stock, or something along those lines?
It was for better reception.
K
Gary
Fl.
Gary
K
I picked up the fender today and you're right it does have
the antenna in the fender
MadOgre
NA
NA
NA
NA
NA
The entire front clip and hood as well as the front doors will swap over.
504SquareBody
