dcfd470
- Jul 17, 2014
- Stafford Va
- Bill
- C/10
I am working on a 1987 chevy 2wd short bed with a 350 in it. I had it running just fine and about a week ago I picked it up from the paint shop it sat for about 3 months and now it will not start. I have tried about everything that I know and I could find on the net and it still does nothing. It will run if I put gas down the throttle body the fuel pump will not come on and the injectors will not do anything. First I checked the fuses and I had the ECMB blown so I changed it and nothing. Next I thought it was the relay so I changed it nothing. I put power to the jumper wire near the relay and the fuel pumps work to each tank when switched. With the key on I have power to the orange wire but nothing to the green wire on the relay. Next I thought it could be ignition control module so I changed it nothing. Next pick up coil so I changed the whole distributor nothing. Next I tried a oil pressure switch(the one next to the oil filter) nothing. I also checked and replaced the fusible links off of the starter and nothing. It between all of this I have checked all of my grounds and they are OK and I checked for power to the injectors and they have power when the key is turned on red and white wire. I haven’t done anything with the ECM yet but I was going to get one and try it out but with the luck that I am having it won’t work. I need any help I can get. I also disconnected the harness and re connected it. The only thing I can find other than it not starting is that the 3amp cranking fuse has no power to either side with key on/off or cranking. And last but probably not least my check engine light does not come on I was going to try to check codes and nothing. Now I am thinking ground again????
Thanks
Bill
Thanks
Bill
