1987 Chevy R20 454 power steering reservoir hose
Gray Beard
Sykesville Maryland
Toni
R20
I am trying to source a power steering hose from the remote reservoir to the pump on my 1987 R20 454. The hose has a 45deg bend at the bottom of the reservoir then a a small bend heading into the pump. To sharp for a straight hose to be used. I looks to be 5/8 hose? maybe 3/4.
Any help with a part number or source would be helpful. All the sites I have been too seem to just have the return hose from the steering box to the pump.
Thanks!
Rumbledawg
the back 40
K30 crewcab
replaced the same hose on my 454 last yr when i swapped my steering box.
bought a Gates hose, #362100...be aware, there not cheap, $50-$90 depending where ya get it
Gray Beard
Sykesville Maryland
Toni
R20
Rumblegawg,
Thanks for the tip, but that seems to be the return hose from the box to the pump. I need the molded hose from the remote reservoir to the pump. Looks to be 5/8 id maybe.
Scott91370
Burleson, Tx
Scott
Sierra1500
If you cant find one you could always have one made. Without the original it may be a little more difficult because they'll need to know the bends and directions of them.
Rumbledawg
the back 40
K30 crewcab
Rumblegawg,
actually it's .72 id and it comes a little long so you can trim it.
this hose will fit from your ps pump to the ps reservoir mounted up high at the front of the block
michaelmarine53
