dcfd470
- Jul 17, 2014
- Stafford Va
- Bill
- C/10
Hi thanks for the site this is my first post. I have a 1987 C10 with a 350 and I just took the engine out to clean and paint it and the engine compartment before it goes to paint. It was running fine when I removed it and I had it running after I put it back in. I was setting the timing and I was moving the dist cap and it stalled and I can not get it to run again. After it stalled it had a code of 42 so I put a new ignition module on it and nothing. I have checked and rechecked the firing order and it is all correct. I am getting spark to the plugs and I check the pickup coil and it is good 861 ohms. I don't know of anything else it could be it just cranks and doesn't even try to fire. I even rechecked to see if I was a TDC several times and it is.
