1986 cold start issue 305
kentrx1
north carolina
kent
Been working on 1986 truck with 305. Have replaced fuel pump, carburetor, and plugs. Runs perfect once it starts. If it sits for a few days/weeks have to poor lots of fuel in carb before it will finally stay running. Once cranked will crank fine all day. Suggestions on what I check next?
Minnesota
1980/1984 Frankenstein
K10 Silverado
I have the same motor with the same type of issue. I as well changed lots of things and nothing made it better. So far my best guess is the engine being old takes time to build enough pressure to start. I do not have to poor anything into mine. It just takes like 10 seconds before it starts and its a really rough start too. It will die right away if I do not keep the rpms up. However, once it gets to a stable idle, it starts fine the rest of the day just like you said.
fast 99
Spokane, Washington
Carb likely dry, It is common for fuel to evaporate when not driven. However, cranking for a few seconds should provide enough fuel to start. Q jets also have well plugs that can leak. If excessive cranking or priming is required would suspect a fuel delivery problem. Check both fuel pressure and volume. Have seen even new fuel pumps that are defective.
Make sure the choke plate is closing.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I would make sure the choke is operating correctly first. Ive found if mine sit for 3-4 days or more they lose prime and fuel evaps out of the carb.
Bigbluesquare
