1986 C 10 Steering column
heavenlyhawgs
Marana Arizona
Jack
383 Stroker
How much work is it to replace 1986 steering column? Can it be done in one day as this is my daily driver?
Snoots
Roger
Jimmy Sierra
350 w/203
Too many questions...
Are you putting an '86 back into your '86?
Tilt or not?
Others will chime in I'm sure. I've changed mine twice before and rebuilt it twice. It's tilt. Did it in half a day and a 12-pack.
heavenlyhawgs
Marana Arizona
Jack
383 Stroker
Yes I'm putting an 86 back into an 86. It is non tilt.
Snoots
Roger
Jimmy Sierra
350 w/203
The locking pawl attached to the key cylinder may be the culprit but first, I would look at the slop in the shifter linkage. Eliminate that slop first.
Phil 83K20
CT
Philip
If you already bought a new column complete and ready to go, it’s a pretty easy job; a few bolts and couple wiring harnesses. The steering wheel is the more difficult bit.
If you want to keep the ignition lock you already have, then it’s more complicated.
I would just go for a new tumbler. The doors dont match the key and you can get copies for cheap and easy
jake26104
