1986 700R4 leaking
BJedi76
Soldotna, Alaska
B.J.
GMC Sierra Classic 1500 4x4 SWB
305”
The pan was leaking, so i replaced the pan gasket, but apparently it had more than one leak.
It is now leaking a lot less, but it is definitely leaking out of the torque converter cover.
What are the possible leak pionts at/near the torque converter
…& can such a leak/seal be replaced without removing the transmission?
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
There is the torque converter seal, it's like pretty much every other shaft seal. Then also the pump seal which is that whole front cover, on a 700r4 the lockup solenoid must be removed to remove the pump, ask me how i know, lolol.
If you have a leak from inside the bellhousing, the trans will have to be pulled to do either of the seals I mentioned.
spartantx117
