1981 C20 lower kit???????
Laine
british columbia
Laine
350 sbc
i have a C20 that is getting a LS swap with a 4L80e, seems drop kits are so far and few between
looking online there is a 3/4 kit with lower control arms for the front and shackles and spring perch for the back for $1000CAD?!?
lots of people telling me to swap out the front member with a 1/2 ton
wierd... I see a bunch of crew cabs lowered, I wonder what they use? I can't believe there isn't at least a lowering spindle or something available for a C20. The rear should be easier, with the shackle inverted the way it is, you should just need longer shackles to drop it.
I guess the first question is "How low are you trying to go?"
mattyb
