1981 3/4 ton 2wd GMC chassis question
81gmc
canada
Steve
Hey Guys can someone fill me in on 3/4 ton chassis vs 1/2 ton and if front end parts are interchangeable I want make it 1/2 ton or know if I can put 1/2 ton suspension up front ?
the 2wd chassis is beefier for a 3/4 ton such as a larger spindle, bigger hub and lug, larger brakes.(I mean, if im wrong someone point it out but I am pretty sure?). springs would be different. no idea about control arms tho. it probably isnt every part
Are you trying to make a 3/4 ton truck into 1/2 ton capability or you just want the ride quality.. maybe wheel/tire options..?
here is a pic of a 3/4 ton 2wd but its not all that helpful, but something maybe?
ali_c20
Austria
Alexander
C20, K5
My c20 is a rough ride but when you haul stuff with it it improves a lot. If you are looking for better ride quality change the springs and shocks.
Welcome from Austria and we want pics btw.
81gmc
canada
Steve
Thanks byes just looking make it 1/2 ton ride and 5 bolt pattern wheels
ali_c20
Austria
Alexander
C20, K5
You would need to change everything ( A arms are different, they have bronze bushings and different ball joints.) to put on 5 bolt pattern wheels. Also calipers and maybe the master brake cylinder too as it is a 1.25 bore for the bigger c20 calipers or you buy a hd c10 rotor than the calipers and mc don't have to go. And the rear axlehas to go too.
81gmc
canada
Steve
That don’t bother me so I would need control arm with rubber bushings and spindles and brakes not big deal thx
it would honestly be easier to find a half ton truck... the amount to change everything over to 5x5.5 and put lower rated springs on the rear(if you have a ff you have to do a lot of work to get 5x5.5 but if you have a semi float its not so hard). are you sure you wouldnt rather just trade or sell your truck? Honestly if you are committed to this truck, maybe buying a c10 to at least have base-parts, you could switcheroo them around
Honestly the difficult part is changing the lug pattern. If you just want a softer ride, changing the springs is just that easy, change to 1/2 ton springs and move on. They are interchangeable, just softer.
rick1956
Edgewood, WA
C2500
Here in Washington you've got to pay more licensing based on the tonnage... the creative folks around here will buy a C10 and transfer everything C20 spring/axle related over to the C10 for hauling capability. I've only seen one that swapped the other way, and it was for sale on Craigy's List.
Rickf
Grafton NH
1974, 1954 & a 1937
Can you use 1/2 ton springs and re-drill the hubs for 5 lug wheels?
Garcjay
