1978 K10 A/C Help Please!
nealdonoho
Alma, IL
Neal
I just purchased a 1978 Chevrolet K10 4wd with a 350 in it. It has the controls for A/C in the cab, BUT everything under the hood is gone. I want to install it back, but I'm not sure what I need and the cheapest place to find it. I'm confused too because I have seen both a short and long style compressor. It does have aftermarket headers if that matters at all, read that somewhere that it makes a difference??? I have no clue on what parts I need and I would like to do most of the work myself and have my local shop charge it. Can anyone help on this please?
Wiring diagram:
The compressor you need will be determined by the style of bracketing that is on the engine. There are 2 basic designs; the A-6 (axial 6 pistons = the long type) or the R-4 (radial 4 pistons = the short/pancake style).
Most likely the bracketing will be set up for an A-6.
Looks like there is a bracket that is bolted on to the stock maifold. Probably can be worked around to fit on your headers.
Compressor choices at Rockauto:
http://www.rockauto.com/catalog/raframecatalog.php
nealdonoho
Alma, IL
Neal
Thanks so much for the response! If I can modify a bracket, you are saying I could use either the A6 or R4 compressor, correct? Just wondering the pros and cons on going one way or the other.
nealdonoho
Alma, IL
Neal
By the way, where can I get a manual that has info like this and other things? I want to learn anything and everything about this particular truck and that has a lot of diagrams like the pics you sent.
chevyk10
WV
Daniel
1984 chevy
k-10
358 Dart block with aluminum heads 430hp/450ft-lb torque
I have almost everything to flip one over. Do you have the box inside and outside for A/C? I have a new sanden compressor for vbelt with brackets and the bracket you need for the headers as well. I have the box that's on the outside of the firewall and some lines that need an end. You would need the condenser. I have an evaporator. I can make you a good deal. I'm not sure how much to ship. If interested pm me and I will send pics.
aaron06
