1978-1987 Chevy K10 Pickup Spindle and Bearing Repair Kit for 4WD Models
1ATony
Tony
K1500
CHECK US OUT HERE FOR GREAT PRICES 1978-1987 Chevy K10 Pickup Spindle and Bearing Repair Kit for 4WD Models
FREE SHIPPING ON ALL ORDERS IN THE LOWER 48 STATES!!!!
This front spindle and wheel bearing repair kit is just what you need to repair noisy and bad bearings inside the spindle and rotor of a GM 4x4 truck. The kit contains enough pieces to repair one side of the truck. The bearings and seals are new aftermarket replacement parts that have the following specifications:
Enough pieces to repair either the LH Driver or RH Passenger Side
The front spindle inner bearing and seal kit includes:
Qty (1) - High quality inner spindle/ axle shaft bearing
Qty (1) - Inner spindle oil seal
Qty (1) - Inner spindle washer
Qty (1) - Spindle to knuckle flange seal
Qty (1) - Spindle to knuckle oil seal
The outer wheel bearing set includes:
Qty (1) - High quality outer wheel bearing
Qty (1) - High quality outer wheel bearing race
The inner wheel bearing set includes:
Qty (1) - High quality inner wheel bearing
Qty (1) - High quality inner wheel bearing race
Qty (1) - Inner wheel bearing rotor dust seal
Replaces one of many dealer part numbers including: 457232, 9437512, 6273948
Direct bolt on replacements
Seal and bearings are built to strict quality control standards
Note: For 1977 models, to determine if your vehicle was built in late 1977, the inner wheel bearing will be stamped with either LM104949 or JLM104910, or possibly both: LM104949/JLM104910. This means that the inside diameter of the bearing is 2 inches. If the inner bearing is stamped with 368A or 362A, this mean that the inside diameter of the bearing is 1 25/32 inches and it is an early model. This kit will not fit the early 1977 built models.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
This part replaces:
Reference #: SBK1, A-35, JLM104910, 471271
flynhigh88
