1 ton rear spring hangers
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i am taking the rear spring hangers off my 90 crew cab 1 ton
front hanger brackets rear shackle bracket and shock brackets
sand blasted and painted black 100 bucks plus shipping
i will post pictures when i get them all off the truck
could be used to put a 1 ton rear in a half or 3/4 ton truck
rear shackle hanger is a bolt on swap the front hangers two holes line up so it would be easy to fit it then drill the other holes.
i am swapping 3/4 ton hangers onto my truck i will be posting pictures and a short description in my build thread if you want to see whats involved in the swap.
That's a nice deal!
The top hole spacing on mine were about 1/4 inch off, but it's nothing that can't be fixed with a press or a vice.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i am not sure what it would take to fit them to a sub or blazer
i just know 2 holes lined up on my swap 1 ton to 3/4 ton truck brackets
The Burb stuff is the same as trucks, at least I thought it was. I suppose it could have been a year difference too.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
all the brackets in the picture x2
front spring hanger
rear spring hanger and support brace
upper shock mount
8T6K5
AZ
L98 350 TPI
...could be used to put a 1 ton rear in a half or 3/4 ton truck rear shackle hanger is a bolt on swap the front hangers two holes line up so it would be easy to fit it then drill the other holes.
What is the benefit of doing this?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i swaped to 3/4 ton hangers for 2 reasons
my blazer tank forced me to move my right rear shock. so i decided to use the 3/4 ton hangers to move my springs out for room betwen the spring and frame for a shock.
and i have a rebuilt 4.10 geared detroit locked 3/4 ton 14 bolt.
look at my build thread for details.
the 1 ton hangers i have for sale could be used to put a 1 ton rear in a 3/4 or 1/2 ton truck. 1 ton 14 bolts can be found military surplus for the cucv trucks or out of a cucv.
could be used to put a dullie rear in a 3/4 or 1/2 ton truck.
the only use i can think off is to put a 1 ton axle in a 3/4 or 1/2 ton truck. nothing to gain as far as performance
the only custom use i can think of is to bring the springs in for a wider tire on a low rider.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
these could also be used for a shackle flip on a 1 ton by just useing the front brackets mounted on the rear for a shackle hanger.
if you are interested in them for that i still will need the same price but if you want to save shipping i can just ship the front hangers if you want.
Snips71
