Clicking steering wheel steering shaft
Mango
JacksonWyoming
Gil
Hey All
I just noticed a slight click in the steering wheel moving it from left to right, i can feel it on the top of the steering shaft under the hood, can wiggle the steering rod at upper connection and ir wiggles< the Bolt is tight??
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Assuming you Checked the rag joint (steering coupler)
I Had one break while driving once.
Mango
JacksonWyoming
Gil
Replaced steering shaft with aftermarket Jeep one Problem Solved
fast 99
Spokane, Washington
Sometimes the horn contacts under the lock plate will make noise. A little silicone grease will eliminate it.
Lfuqua20
