SM465: Difference between 2wd and 4wd
Designo614
New Bern NC
Chassis Cab Tow Truck
I have a 1988 C30 with SM465, 2wd. Something's broken inside and I have a chance to pickup another SM465, but it came out of a 1987 4WD K series. Research indicates that while the later versions each had a 35 spline output shaft, the 4WD version is longer. Can someone confirm whether or not I can swap these directly? If I have to change the output shaft, I guess I'll just rebuild what I have.
nvrenuf
Mobile, Al.
2wd’s were all short 35 spline.
4wd’s were either short 10 or long 32 spline, there are no 35 spline 4wd transmissions.
Converting the trans would require 75% tear down assuming the parts you need from the old trans are good.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
It's relatively cheap. Just rebuild yours. 2wd 465's are the most plentiful trans in my area.
Designo614
New Bern NC
Thanks! That's what I needed to know-
scottyray
