Setting Timing
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Gotcha, well hopefully it doesn't come down to that. This timing business is serious stuff. Would msd do anything to help?
If you would run a digital retard box but that’s usually for boosted applications or rpm based timing curves for staged nitrous set ups in conjunction with some form of manifold pressure sensor way more advanced then you need.
Wdschell
California
Waylon
Gmc Sierra Classic
5.3L
I would like some nitrous eventually, but I'll save that for another time. Thanks for all the help too
Rusty Nail
Rusty
350sbc
Good evening everyone,
I have been trying to tune my timing for a while now and have read just about every thread on timing there is on here or hotrod.com etc and I am still confused.
My question is when setting my total timing, do I set the RPM that I want the mechanical advance to be all in at and then tune it to 34-36 degrees from that? Or do I just set it to 34-36 at when the mechanical advance stops coming in?
I have a cheap amazon distributor that i have replaced the coil in with a standard GM coil since the one it came with went out
here is the link. http://a.co/fHmomfo It says it has total 32 degrees timing.
My Pickup seems to drive around fine until I am on the highway cruising at 65 and try to accelerate or go up hill and then I get some ping. Have a 327 with mild cam and current initial timing setting is 14 degrees btdc.
Use a 3/32 allen wrench and stick it in the vacuum canister of the distributor.
Take 1 full turn counter-clockwise and drive. Repeat until ping stops.
It's easy.
You gotta be careful listening to all these monkeys in here.
spanky55amg
I'll give u $5, a hardy handshake, & 5 fish sticks
Dallas, TX
Spanky
C10 Short Fleet
V8
somebody snapped this when I was trying to fix my carb.....
Maybe that monkey can fix my carb too, hahaha. He looks to be doing a better job than me.
or
Wait! Were you at my house last week? Creeper. Because thats how I feel working on that Holley.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
What heads, cam, and compression ratio are you running? They play a role in what timing is optimal.
Wdschell
California
Waylon
Gmc Sierra Classic
5.3L
Well one of the problems was my distributor was junk and not producing good spark. Fixed that and seems to be working better. I have 14 initial, 14 vacuum and 21 mechanical. I had it at 12 initial but it seemed to be stuttering in the low rpms range
Not sure about the cam but the heads are the 289 power pack ones I think. I bought the engine on Craigslist and it's a 327 built from a 350 block
Wdschell
California
Waylon
Gmc Sierra Classic
5.3L
I also think I may have a vacuum leak from my brake booster. I replaced it last week, but when I hit the brakes at idle the rpms go up
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
And also if it has the ***** filter on it, well throw it away.lol
74 Shortbed
As in Fram, lol..
Wdschell
California
Waylon
Gmc Sierra Classic
5.3L
Ah. It does have that inline thing on it.
satansdad
