Vent window trick?
Elliot W
CT
Elliot
This seems like a great idea. I need to replace my weatherstripping but had lost motivation after reading how big of a headache it is to do this job. Based on others' experiences, I figured I would pay the $500 to Precision to have them deal with the headache, but this gives me hope. This means I wouldn't have to take the vent window assembly out of the door correct? Are there any other difficult parts of the weatherstrip install that are a pain?
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
One of the main reasons I asked about this is because I already replaced the window channel seal on the red truck. Didn’t want to take a chance of screwing that up taking it back out. It may make a difference though if I have a two piece vent window seal. I’ll have to investigate that.
Daron58
Ponchatoula La.
Daron
250 I6
I used the 2 piece vent window seals, I borrowed a mini rivet setting press tool from a friend, use plenty of lube non-petroleum based and take your time, it’s very doable just a little patience and you can do it. Good luck
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
brooksman9
Olive Branch, MS
Patrick
350 & 305
Craig please post back what luck you may have. I’m not planning to tackle that anytime soon but thought it was a neat trick when I ran across it.
Bennyt
Surprise
Ben
My 2 cents. While this is a neat trick that will work for many, and may be a temp repair to get you through until you can tear it apart....I think this is best reserved for the show vehicle that gets limited use. In the link, it was a '63 Continental and I suspect that it's not being driven much. If the seal does fail, most likely it's just a short drive home to repair. My concern is a lot of folks on here drive their trucks daily/ regularly and possibly in adverse conditions. They open and close the vent windows a lot more than the guy that only goes to shows. Be interesting how it holds up for those.
brooksman9
Olive Branch, MS
Patrick
350 & 305
Finally got the latches from Amazon. The snow delayed them a bit. They seem to work fine. More parts in the bag than you need or can fit in the glass. Look nice. Made in Taiwan. Better that what I had for sure. We'll see if they last.
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
We did ours, two piece set from precision. Took a while. Took one frame apart and not the second. Both came out great. But as posted above take your time, walk away when you have to!
The refurbish at precision is a great deal as everything is included including powder coating frames which we were unable to do but they came out fine.
Randy and Easton
Snips71
