c10 5.0L rear diff fluid
79Scott
N37°20’26” - W77°40’34
Scott
C10-Silverado
305ci
Hey guys, was going to change my rear differential fluid over the weekend. What is the factory suggestion? 75w/90? and how much?
Thanks
dvdswan
Port Orchard, WA
Dave
75w/90 is fine but if you have a LSD you should put an additive in or a specific LSD gear oil. 10 bolt holds about 1-3/4 qts, 14 bolt holds about 3 qts. IIRC.
79Scott
Scott
C10-Silverado
305ci
Thanks Dave, I just noticed I prolly should have put this on the differential driveline section......o_O
Snoots
Roger
Jimmy Sierra
Get yourself a magnetic fill plug while you're at it.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
I just put my 10 bolt in i put 2 quarts (plus some) of 80-90 gear oil plus a tube of LSD oil in. I fill till it starts seepin out the fill.
80BrownK10
Greenwood, SC
Nate
80 w90 works. Don't forget additive if you have limited slip.
I have a 12 bolt and I was thinking it took like 2.5 quarts?
aaron06
