- Apr 11, 2017
- kansas
- Rick
- c20
Something just occurred to me as I was reading another quadrajet extended crank after sitting thread. I haven't had a chance to explore this,because I just thought of it 2 minutes ago. Many people have extended crank after their qjets sit a few days. Some of you know and some of you don't,but there are 2 types of needle and seat for a quadrajet windowed and not windowed. Windowed has windows in the side at the fuel bowl floor,non windowed do not they are tube with no windows. I have a theory that the fuel is boiling off or evaporating off enough to let the float drop. Now as soon as the float drops the needle will open and let the fuel drain all the way to the floor of the fuel bowl. Now a non windowed seat would not let the bowl drain completely.Also the correct fuel filter for a qjet on a 3 port pump vehicle is supposed to have a check valve in it. I suggest anyone having an extended crank problem try a non windowed needle and seat and be sure they have the correct fuel filter. Post your results,as soon as I have one with a problem,I'll try it to see if we have a fix.
