Key release on column stuck
Croc1990
Saskatchewan, canada
Dakota
So I replaced my ignition cylinder, old One key came out in any position and was borderline about to snap in half(plus the chrome piece had disappeared a while ago).
Put new one in it cycles fine but to release the key I gotta jerk that release super hard to get it to move and is really loud. I imagine that's from years of just not using it. Is there a way to loosen that up without breaking down the column?
when trying to get metal parts like that to free up, the best timre would have been without the key cylinder in it . when i replaced my key cylinder in my column, it had been YEARS iwithout usage too. only manual trans columns should have the lever. and mine worked flawlessly, im wondering if yours isnt binding or if the internals arent potentially worn. BUT if you need to free things up, something like a column I would use a dry lube first like
This would be best ot use on the lock/key/interlock parts of your column
Croc1990
Dakota
I will take everything apart further once it warms up and check it out.
From what I could see is the rod and steering lock nub were engaging almost all the way when I had it apart.
Wrenchersllc
