WFarm
Central Virginia
K5 Blazer
Power steering pump has been leaking from the main O-Ring between the pump and reservoir so pulled it today and did a partial rebuild, replacing all the O-Rings. Got it buttoned up and tested and all seems dry at this point.
Travlr
Central Utah
C
K20 Camper Special
Jacked it up yesterday to try and see why my 55mph vibration has come back
The weights are still there on the driveshaft, so it's not that. It had slung a weight a while back and was shaking pretty good at 55, had a good hum at 70 and really didn't like 82+ on my last couple trips. It's still dead smooth at 70 and all the way up to 95, it only has a side to side shimmy at 55mph. I'm starting to wonder if I need hubcentric rings for the wheels. I need to measure that.
Did you get the rims at tire rack?
ChuckN
Bellinham, WA
Chad
Sniper wired to the battery and I made it as streamlined as possible. Then I made a little “L” bracket to mount the relay and fuse to the firewall stud.
awar
K35
Went to the dump with the trash trailer made from the rear half of my donor 94 C2500 6.5td/4L80. This truck had a nice flush fold down ball gooseneck hitch. I did not remove it when I made the trailer out of the truck. So after the dump run I washed the bed out and backed it into the shop. Up on the hoist for inspection, gather tools and spray Kroil on all the bolts. After a good soak time all the nuts came off and the hitch is removed. Then reaching through the hole in the deck I removed the last for bolts hold the reinforcement. This will let me have a gooseneck hitch and still have a pretty flat floor. I just need to install it during the bed repairs. Similar to these pictures only the underbed reinforcement is 1/2” x 3” steel plate, very heavy duty.
Camar068
Air Force Supporting Member
Kentucky
10 yrs Air Force
It certainly sounds like assembly in March was not done properly.
here's a thought. I added coil overs in the front years ago. Sounds right it's about the same time I started busting spindle nuts. I'm not super aggressive driving, but I do like the throttle thru turns up until the body rolls. No monster beating (using 4x4 busting over crap....I'm more gently during those times) during deer season. So in my eyes, mildly aggressive daily.
ditch and go back stock?
Moderator
I can't see how those shocks could cause those issues at all.
My daily '05 1500 has this style goose in it, it's hilarious. Dude towed a small, aluminum 16' camper with it. I haven't removed it cuz I figure the extra weight makes it ride a tad better lol
ChuckN
Bellinham, WA
Chad
Got back out to the garage this morning. Pulled the thermostat and put in the spacer that houses the coolant temp sensor. While I was at it, I noticed that the heater hoses were reversed, had been that way since the PO, so I switched them back. Guess it doesn’t matter that much since there was never any ill effects.
Put the AN fittings on the Sniper unit, threaded in the gauge, and put the block-off plug in the rear fuel outlet. Also connected all the vacuum lines. Besides refilling the coolant, there’s nothing left in the engine bay to do (well, the hose itself, but I believe I’m supposed to purge a gallon of gas through it before first fireup).
I’m going to do other stuff for the rest of the day until the feeling comes back. Spent a good chunk of the day yesterday helping my buddy put a fuel tank and fix fuel lines on Colonel Mustard (1972 GMC) then got to work on mine afterwards and again today.
I envy you guys that can just tinker and then walk away from it cuz you have a reliable, normal daily. When the daily is also as big a project as the project, the project HAS to get done and stay together until the daily project is no longer a project...until next time anyway :lol:
Moderator
Open your eyes man!!! You have TWO projects! Lol
ChuckN
Bellinham, WA
Chad
It’s easy- daily a minivan. You’ll never want to do a thing with it except run to the home improvement store or haul the family around.
79TanSquare
