Threw it on my cribbing yesterday for a long overdue look at the pinion angle. I never looked at it to start with, the first few drives were smooth as silk so I didn't worry about it. I've picked up a vibration pretty much ever since or shortly after getting the new wheels on. It seems to phase a bit (worse sometimes than others) and it's always right around 55mph and then a very much milder vibe at 70ish. Kind of thought it might be my rear tires because I reused these from my last set and it took 4 attempts to get them balanced on the old wheels but wanted to check the driveshaft/pinion angles anyway
The angles aren't a dead nuts same but opposite but they're within 1/2 a degree of each other, according to Spicer's calculator I'm good. Looking around the shaft, this weight is good...
Um, wait a min. There might by my vibration. Called the driveshaft shop, they can't get me in till next week. No biggie, I can drive around it
The aren't supposed to match exactly, they are supposed to be I think 1° different to make sure the caps rotate. Also some allowance for axle rotation. If you are within a degree ujoint angle is not your problem
Jimbarry
California
C30
I finally started on my to do list. I pulled the plugs to try to figure out why I get smoke and fumes every time I start aptly named Smokey .The plugs are oil fouled so I did a compression check. 120 to 130 in8 cylinders, not bad for an 83 454.
I think the oil is coming from the galley through the intake, I replaced it a few years back in a field with no way of dropping it in place correctly so I think the intake is sucking oil.
I removed 22 hoses from the manifold, carb and water inlets Dontchajust love clean air.
Pulled intake off./reinstalled intake with new gaskets.
Installed spark plugs AC Delco R44T .045 gap.
Replaced burned distributor wire/connectors.
Good so far, no smoke and idles well.
Removed ac components that have not been turned on in 5 years, flushed everything, spliced hose that was leaking, evacuated and recharged. Blows cold after 2 weeks.
Removed leaking power steering pump/reinstalled used power steering pump Ihad laying around from another project. Lucked out, it works with no leaks!!!
Buffed out and waxed, looks pretty good.
Need to reinstall ac vent under dash, and replace drivers side valve cover gasket which just started leaking then, just drive for a bit.
Supporting Member Army
Suburban tanks with Suburban crossmembers will work in a pickup frame. There are several differences in the frame configurations. Suburban frame rails are straight at the front crossmember location and slope down at the rear crossmember location. Pickups are the opposite. The frame goes up in the front and straight out the back. I settled on putting the rear crossmember where the factory pickup crossmember mounts. I got one bolt on each side to fit in factory rivet holes. I wanted the seam in the fuel tank to be level with the frame, the same way it is mounted in a Suburban. I had to trim the front crossmember and space it down 1.5”, picture shows a temp spacer. I will build a 1” spacer for the bottom. 1/4” frame rails on this one ton frame.
Now for the bed, the Suburban tank sticks up past the top of the frame rail and the fill is too close to the wheel well. There are three crossmembers at the rear of the bed that sit on the top of the frame. The front one will interfere with the tank itself and is in the way of the fill hose. Suburban body tubs are one piece and are mounted like a pickup cab on rubber mounts. There is clearance between the body tub and the frame on a Suburban. I will modify the crossmember that interferes for clearance between the frame rails and outside of the frame on the passenger side for the fuel fill. I am adding a third fuel door to the bed so there will be two on the passenger side. One in the factory location and behind the wheel for the Suburban tank. Truck will hold 80 gallons of Diesel when done. The truck I built in 2005 holds 95 so it will be close on range without the inbed tank.
P
That looks like the 31 gallon tank... are you sure its a 40 gallon? The 31 gallon is basically square ~28"x28"x12.75". The 40 gallon has an extra 6" in front to back length and about 1/2" more depth. My 31 Gallon tank looks just like that and seemed to be about the same distance behind the rear axle as yours appears to be.
Battlac40
New Mexico
James
K1500 Sierra Classic
All new valve seals, carb rebuild, locking header bolts, coated long tube headers, rear intake vacuum tree and hoses, oil pressure sensor with intake clearancing, low pressure power steering hose and clamps with fluid flush, MSD tune up. Still need to figure out a PS pump brace that clears the new headers. OG bracket fit on the shortys but not these.
I've put a pic of that brace up twice. Easy to make. I'll look for my pic. BRB 3rd post downnI think.
gilby959798
CLT NC
GMC K25 Camper Special
Went to the C10 Fall Revival to get some ideas and met up with @TotalyHucked for a bit.
Moderator
Ok, who sells those pre-made houndstooth covers?!
awar
K35
Bextreme04 you are correct it is a 31 gallon tank. I have a 40 in my truck now and a 60 in the bed. I took several trucks apart before assembling my truck in 2005. I kept this tank and frame brackets including the skid plate. I never checked to see what size it was. It has been in the parts shed since the early 2000s. I ordered new straps, a Diesel fill pipe and the cover over the fill pipe that I will install in the bed along with a fuel door that I have saved. I assumed it was the same as the tank in my truck since it came out of a 3/4 ton Diesel Burb.
Mango
JacksonWyoming
Gil
Changed my oil filter from cheep Naps to Mobil 1 and added Lucas zinc additive 6 0z to my existing oil last change 543 miles ago with Napa 10w-30 oil will this continue to keep this engine running with 205,265 miles ? Burns oil only at start up valve seals leaking and some oil on the bellhousing do not like Synthetic oil too thin and may cause more leaks due to removing sludge and old seals ???
awar
K35
The only thing is I have found that synthetic oil does not smoke as much as conventional oil. It will still burn oil if it is an oil burner but not smoke as much.
You don't need zink additive with mobile 1 also too much zink is bad also. It also causes damage to cams.
Sorry had to come edit this god I'm getting tired of my phone correcting my posts. You type one thing hit reply and when you look at it later it says non sense stuff. Anyone know how to stop the phone from auto correcting.
Terlingueno
Far West Texas
Skeeter
K20 Suburban
350/SM465
The original engine in my '85 K20 Burb made it to 315,000 miles before I had to replace it with a GM crate engine since oil consumption was becoming an issue. I used conventional Castrol 10w30 starting when I bought it at 70,000 miles until 2008 the crate engine went in. This oil had reduced ZDDP and it got lower in 2004. Since it was a bone stock engine and the cam/lifters were already well broken in, no issues. When the shop took the original engine apart, they said there was no notable excessive wear on the cam/lifters other that the 315K miles on it.
That shop suggested I use Valvoline VR1 10w30 with good levels of ZDDP so that is what I have been using since the new engine went in. There was a three year period that due to summer temps exceeding 100F, I would switch to Castrol 20w50 Classic, but I don't do that anymore. But makes me feel better that the VR1 and the Castrol Classic have high ZDDP.
79TanSquare
