Dejure
- Mar 3, 2025
- Eastern Washington
- Kelly
- C15
One of the forum topics that surfaces from time to time is, problems with the heater circuits. In the course of these conversations, the topic of THE (as in singular) heater relay comes up when discussions start about damaged switches.
People, rightfully, point out the relay takes the load off the switch, greatly extending its life. However, and aside the fact many rigs, like mine, don’t have any heater relays, the problem is, Detroit only saw fit to install one relay, to protect the high speed circuit, but the medium and low fan speed contacts of the switch carry the same amount of damaging power as the high speed circuit.
The other speeds are accomplished via a dropping resistor, where the balance of power is dissipated. The power dropped across the heater dropping resistor and the blower motor still add up to the power that eats the high speed switch position contacts.
Based on the foregoing, the lower speed circuits need relay protection too, to reduce the hit they take.
For the reasons stated, I'm using the output of the heater control circuits to activate three relays that will feed power to the fan. Directly for the high speed, and to the heater dropping resistor for medium and low speeds.
To add the relays, I bought relay plugs that came with 4 pin relays. However, when I got them, I discovered they work by mounting the relay to a surface via removable clips, and the cable are free floating.
I didn't care much for the free floating cable approach, so I built holders that mount to the firewall and through which the plugs can drop. Once in place, the relays just press in for quick swaps from a different approach.
One other advantage of the holder is, I will be able to print tags (e.g., "HEATER," "HIGH," "MEDIUM" and "LOW") to make locating and troubleshooting the circuit easy.
SIDE NOTE: I printed in ASA filament, said to be able to take high heat, so it should hold up to the engine bay heat.
